The Wall
Forum / Oil Heating / copper fill and vent pipes
  • Post a Reply to this Thread
    copper fill and vent pipes (8 Posts)
  • earl burnermann earl burnermann @ 5:16 PM
    Contact this user
    I was just on a job, new construction, and noticed they had installed the fill and vent oil line using copper. I know that every oil company I've ever worked for would not repair these pipes, you had to have the piping redone with black pipe if you had a problem. My question is are you allowed by code to use copper for this purpose? I'm not having any luck looking it up.
    Thanks.
    If the women don't find you handsome, they should at least find you handy!
  • billtwocase billtwocase @ 8:29 PM
    Contact this user
    Where are you located Earl?
    Copper is a no-no here in Mass for a fill and vent. Oil supply line yes, just not bare copper
  • earl burnermann earl burnermann @ 10:07 PM
    Contact this user
    I am located
    On long island in Suffolk county.
  • Tony Massi Tony Massi @ 10:57 PM
    Contact this user
    Copper piping for oil tanks
    Its been all allowed in the Town of Brookhaven for some time. They used to allow the fill and vent pipes to piped in PVC years ago.
  • earl burnermann earl burnermann @ 8:35 AM
    Contact this user
    Thanks
    For the info.
  • Steve Steve @ 1:36 PM
    Contact this user
    tank pipes..
    check  NFPA #31...see what they say...
  • papashawngo papashawngo @ 6:23 AM
    Contact this user
    the solder
    in canada we cant use copper fill and vent because the solder used for the connections has a melting temperature less than 1000degrees Fahrenheit. the oil supply line to the furnace is fine because it uses flared connections.
  • Bricktop Bricktop @ 5:49 PM
    Contact this user
    It depends on the filler material
    I think it's ok as long as the joints are brazed and not soft soldered
