The Wall
Forum / THE MAIN WALL / Air compressors
  • Post a Reply to this Thread
    Air compressors (4 Posts)
  • Jack Jack @ 11:07 PM
    Contact this user
    Air compressors
    Kinda sorta off topic, but thought I'd ask. I've got a substantial structural steel project here at the house and all my compressor filtration gear got lost in the move west. What do you use to filter and dry your compressed air? I don't want to pump a bunch of moisture into my plasma cutter. Thanks for the help
  • hot rod hot rod @ 9:31 AM
    Contact this user
    depends on
    how much air you compress and the humidity. Here in Missouri I tried those throw away plastic moisture traps. But if I use the plasma for 20 minutes or more the filter is saturated.
    I see the pros use a quality refrigerated moisture removal system. I just bought a nice airbrush so I need to upgrade my moisture removal system. I guess you get what you pay for. For as much as I use mine I may just up-grade to a larger capacity inline trap.
  • RJ RJ @ 10:16 AM
    Contact this user
    Air
    I would use what we used for years for pneumatic controls,  Use a inline modular filter system, first a dirt filter than a oil filter (available at Graingers),  Than a refrigerated air dryer, also a auto or manual blowdown for the air compressor tank.
    RJ
  • SWEI SWEI @ 8:08 PM
    Contact this user
    We've used these for years
    with good results http://www.motorguardplasma.com/2plasma.html
    This post was edited by an admin on September 10, 2013 8:09 PM.
