The Wall
Forum / Radiant Heating / Taco 007?
  • Post a Reply to this Thread
    Taco 007? (5 Posts)
  • ChadZeilenga ChadZeilenga @ 4:42 PM
    Contact this user
    Taco 007?
    I have a steam system that was converted to a 2 pipe sometime in the past.  I have a cast iron boiler that is ~20 years old.  Last winter I replaced the old Honeywell L8148E with a Beckett Aquasmart controller.  I believe the B&G Series 100 is original to the boiler, and I'd like to replace it.  I believe the Taco 007 is a suitable replacement and shouldn't pose any issues with my Aquasmart.  Does anyone have any experience with this?  My home is ~2000 sq. ft, 2 story and a single zone.
    This post was edited by an admin on September 16, 2013 4:42 PM.
  • SWEI SWEI @ 4:54 PM
    Contact this user
    Is it working OK now?
    What kind of ∆T are you seeing on the system?  007 curve is different and the Series 100 is completely rebuildable.
  • ChadZeilenga ChadZeilenga @ 4:57 PM
    Contact this user
    Cold start
    The boiler is set up as a cold-start boiler with the "learn" function active on the Aquasmart so it determines its max temp. I believe it was around 140F though.
  • SWEI SWEI @ 7:52 PM
    Contact this user
    By ∆T
    I mean difference between supply and return water temps when firing on a cold day (ideally a design day.)  Translation:  Is the Series 100 moving more water than you need?
    This post was edited by an admin on September 16, 2013 7:53 PM.
  • ChadZeilenga ChadZeilenga @ 8:31 PM
    Contact this user
    Delta T
    Sorry, I don't have that info. Should have gotten that before the winter ended. I would have to wait until JAN to get true numbers. I believe the pump is original to the boiler installation. The whole system is a high mass with all cast iron rads. When I installed the Aquasmart I started to get kettling inside the boiler so I thought the pump might be bad and was going to swap before the weather got too cold.
