The Wall
Forum / A-C, Heat Pumps & Refrigeration / ac system design help
  • Post a Reply to this Thread
    ac system design help (6 Posts)
  • hws hws @ 5:01 AM
    Contact this user
    hey guys,
    I have a potential customer who wants zoned AC in a small office space using a multi-split heat pump. Did a load calculation & found that each office requires 5-600 BTUh of cooling, obviously mini splits are a bad idea (smallest indoor unit I can find cools to 9000 BTUh.). So I am looking at other ideas.
    The entire office suite is only 1250 sq ft and could in theory be cooled by one mini split if it were open concept, but each office/room requires its own zone.
    I've been thinking about presenting the customer with other options, such as zoned ducted AC with a variable-speed air handler and motorized zone-valve style dampers. However, I'm not up on AC duct sizing. Don't want to undersize.
    Is there a sizing rule-of-thumb for AC ducts, something I can do to get a basic calculation of sizing for the purposes of working up an estimate?
    I am doing a duct design course this winter but this job came up too early!
    Thanks guys! If anyone has other ideas on how to configure this system, I'd love to hear these also
  • RJ RJ @ 2:47 PM
    Contact this user
    sizing
    I would find someone with a background in ductwork to help.    Get a Trane Ductulator, the Trane air conditioning manual ( hard back book ) and fan curves on your equip. to get started
    RJ
  • hws hws @ 9:04 PM
    Contact this user
    hello RJ
    I'm doing an air system design course hopefully this winter.
    Since I wrote the original post, I have acquired a ductulator and learned some useful formulas, which has opened my eyes quite a bit.
    Regarding the Trane AC manual - is it available directly from Trane? I don't see it on their website.
  • Jack Jack @ 10:18 AM
    Contact this user
    The minisplit is still your best bet
    You could do a multi unit and use the small concealed air handlers. They have very low static so position to minimize ductwork. Your other option is a minisplit and add a few Tjernlund Aireshares.
  • hws hws @ 9:02 PM
    Contact this user
    looks like
    Looks like it's going to be mini-splits after all. Owner doesn't want to compromise celing height. Thanks!
  • RJ RJ @ 9:47 PM
    Contact this user
    book
    available online  Bookmark Inc   1-800-642-1288, or check your local Trane supply house  $40.00,  well worth it
    RJ
