The Wall
Forum / Controls / Logimatic R2107 Help Needed
  • Post a Reply to this Thread
    Logimatic R2107 Help Needed (2 Posts)
  • zooba72 zooba72 @ 10:12 PM
    Contact this user
    Hello Everyone,
    I need some help with my Buderus Logimatic R2107 configuration.  I’m running a Burderus G215-4 boiler (OIL) and
    have 3 zones in the house.  Zone 1 is the
    main living area (upstairs & downstairs), Zone 2 is the basement, and Zone
    3 is the domestic hot water supply.   I’m
    trying to set Zone 2 (Basement) to a temperature around 50 degrees for both day
    and night (50 day / 51 night).  However
    when I try to hold down the Heating Zone key to select the basement zone, I
    only have one circuit and DHW.   Can
    someone please explain what I need to do in order to modify the temperature of
    the basement zone?   I ended up heating a
    gutted basement last winter and it cost a fortune.  The manual makes reference to module FM241 … Do
    I need to purchase another module to modify the basement zone?   I have thermostats in both zones, but the
    Logimatic is controlling everything.
    Please help!  Thank you.
    I apologize if this topic has been covered before, I couldn't find it in the forums.
  • tangled in wires tangled in wires @ 2:14 PM
    Contact this user
    can you increase decrease daytime and nighttime temps?
    First off are you able to adjust any of you zones current temperatures Ex: Zone 1 adjust day temp to X degrees?
    If you can adjust the daytime and night time temps switching zones should be fairly easy.
