The Wall
Forum / THE MAIN WALL / Water Filter for Alum HX
  • Post a Reply to this Thread
    Water Filter for Alum HX (5 Posts)
  • StefK StefK @ 11:49 AM
    Contact this user
    Hey All...
    Just wanted opinions on if a water filter would be a the way to go with a Buderus 142 gb because of the aluminum HX and if it was also a good idea to use one with a SS HX as well.
    Thanks
  • SWEI SWEI @ 12:06 PM
    Contact this user
    Water treatment
    e.g. http://www.rhomarwater.com/products/residential-hydronic-radiant/ is pretty much mandatory for an aluminum HX.  IMO it's a good idea for any boiler.
    Filtration would be applicable to fill and makeup water and would depend on the water in question.  Most water problems are chemistry-related and will not be affected by a filter.
  • hot rod hot rod @ 5:15 PM
    Contact this user
    a dirt separator
    is a good investment for any hydronic system. It keeps any small and large debris out of pumps, zone valves, heat exchangers, etc.
    Y strainers work but are limited by the screen size, and can plug and reduce the flow in the piping. A separator removes and traps the particles, down to a 5 micron size, below the fluid stream.
    Consider a separator with a magnetic component to keep any ferrous oxide out of the components.
  • Jamie Hall Jamie Hall @ 5:13 PM
    Contact this user
    Won't hurt anything
    won't help anything either.  Filters filter particulates -- however small they may be.  Problems, if any, with heat exchangers come from the dissolved chemical makeup  of the water, and filters won't do anything about that.
    Of course, if your water is seriously full of particulates... but I hope it isn't!
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
  • StefK StefK @ 1:41 PM
    Contact this user
    Thanks
    Thanks for the info ....
