The Wall
Forum / THE MAIN WALL / primary/secondary
  • Post a Reply to this Thread
    primary/secondary (3 Posts)
  • Paul S Paul S @ 11:58 PM
    Contact this user
    primary/secondary
    When using a regular atmospheric hot water boiler with primary/secondary piping....how do I control the primary pump? System is going to have four high temp baseboard zones.....and three radiant zones with 3 way mixing valves.....should that I use a relay to turn primary pump on whenever any zone call for heat or outdoor reset Paul s
  • The easiest way
    is to wire it off the boiler if it has a pump relay.
    If not, create you're own pump relay off the end switches as you say.
    Often wrong, never in doubt.
  • Paul S Paul S @ 12:14 PM
    Contact this user
    primary/secondary
    Do you recommend one pipe primary secondary or two pipe on a residential home? Heat loss of home about 160000btuh's...thanks Paul s
