The Wall
Forum / Strictly Steam / Burnham MST.....
  • Post a Reply to this Thread
    Burnham MST..... (6 Posts)
  • kcopp kcopp @ 11:57 PM
    Contact this user
    Burnham MST.....
    Does Burnham/ US boiler still frown upon gas conversion burners? Have they seen the light?
  • Robert O'Brien Robert O'Brien @ 7:40 AM
    Contact this user
    No
    Shortsighted IMO
  • Steamhead Steamhead @ 9:22 PM
    Contact this user
    Every time I talk to someone at Burnham
    I remind them that we want a gas MegaSteam.......
  • BobC BobC @ 9:49 PM
    Contact this user
    I contacted them last year
    when I was about to buy the Smith G8 and put a Carlin EZ-Gas on it. I explained that I would like to use the MegaSteam instead because I thought it a superior boiler. They replied and told me they would not sanction putting any type of gas boiler in the Megasteam and they referred me to the IN series of gas boilers.
    There obviously someone very high up at Burnham who is very much against the idea of a wet based gas fired boiler and from the reply I got it is not the sales staff.
    Bob
    Smith G8-3 with EZ Gas @76,700 BTU, Single pipe steam
    3PSI gauge
  • MarkS MarkS @ 5:21 AM
    Contact this user
    Reason?
    Has Burnham said why they're opposed to a gas burner on a MegaSteam?
    Homeowner, Royersford PA | 1890 one-pipe steam system | 3009 sf | 3 floors | 14 radiators | Utica SFE5200S boiler
    NEW Midco LNB-250 Modulating Gas Burner | EcoSteam modulating controls | 70 to 300 MBH |
    607 sf EDR connected load | Operating pressure: 0.5 oz/in2
    Four main runs (insulated) totaling 135 ft in length | All Gorton vents on mains & rads |
    A Steam Odyssey | Odyssey 2 | A Steam Enthusiast's Outdoor Reset Control
  • Dave in QCA Dave in QCA @ 11:33 AM
    Contact this user
    Energy Star Rating?
    The Burnham Megasteam is rated at 86% when firing oil and that gets it into the Energy Star club. There are few others that can make that claim, if any. The Smith 8 series running on steam and firing oil does not quite make it.
    When the efficiency of oil firing and gas firing are compared side by side at the AHRI site, gas always runs 1.5%-2.5% less efficient. So, if the Megasteam was marketed with a gas burner, one might guess that the efficiency might be in the area of 84% That is not bad at all, but it is not good enough to get the Energy Star rating. And that would be bad for the marketing plan for what is perhaps the only energy star rated steam boiler.
    The obvious solution to the dilemma is to market a gas version of the megasteam with a different name. Perhaps it could be the Burnham Supersteam gas. I would have bought a couple of them!
    I would also guess that there is disagreement on this whole issue inside the Burnham corporate management structure. The side of the argument that says "we can't market the Megasteam as a gas burner" is winning. The other side that wants to do it (there has to be someone inside Burnham that thinks it's a good idea!) simply has not figured out how to go about it. And so, the silly story continues. Burnham won't market the Megasteam with a gas burner because for some reason they think that they can't. But, they just haven't figured out how, or the person in charge who decided "we can't" won't listen to new ideas, and perhaps doesn't want to admit that he's wrong.
    Corporate Management 101. How to admit you're wrong without admitting you're wrong, and taking someone else's great idea and making it like it was your's all along.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
