The Wall
Forum / THE MAIN WALL / Will it work?
  • Post a Reply to this Thread
    Will it work? (7 Posts)
  • hairball hairball @ 11:26 PM
    Contact this user
    Will it work?
    Will one of the wall unit condensing boilers work with cast iron radiators?
  • kcopp kcopp @ 12:21 AM
    Contact this user
    You betcha...
    If it is piped to specs. Furthermore it is a match made in heaven.
  • nicholas bonham-carter nicholas bonham-carter @ 12:28 AM
    Contact this user
    Radiators and new boiler
    It's a perfect combination of high mass radiators, and a modern condensing boiler. However, the cheaper look-a likes from the big box store may only be water-heaters, which will not work as boilers.--NBC
  • hairball hairball @ 9:56 PM
    Contact this user
    Thanks
    Who makes the better condensing boilers?
  • hairball hairball @ 10:06 PM
    Contact this user
    one more thing for now
    Some of the boilers I am looking at rated by input. How will I now what the output is. Right now I have a gas conversion burner that set up with 100,000 input would the condensing burner be about the same.
  • Zman Zman @ 11:31 PM
    Contact this user
    Heat loss
    The only way to correctly size a boiler is to do a heat loss calc.
    The output is the input derated by efficiency.
    A 100,000 BTU boiler that is 90% efficient would have an outputĀ  of 90,000 BTU at sea level.
    Lochinvar,Triangle tube and ViesmannĀ  are some good choices.
    Carl
  • hairball hairball @ 11:47 PM
    Contact this user
    thanks
    Thanks for the help everyone.
    Chris
