The Wall
Forum / A-C, Heat Pumps & Refrigeration / Taking out a cooler
  • Post a Reply to this Thread
    Taking out a cooler (3 Posts)
  • Myglide13 Myglide13 @ 9:13 PM
    Contact this user
    Taking out a cooler
    A local store owner has a 2 door and a 3 door 'zero zone' reach in coolers both running off of the same compressor using 404A. I am being asked if I can take his 2 door unit out due to him expanding a room and he's in need of the space not the cooler. The compressor is sized for the both and basically the 3 door calls and they both get cooling. Other than the compressor being oversized is there anything I'm not aware of if I cap off the 2 door and get it out of the circuit? Each reach in has its own expansion valve and defrost. Thanks in advance.
  • Techman Techman @ 7:26 AM
    Contact this user
    oversized comp
    Besides killing the comp.not much!
  • pecmsg pecmsg @ 11:48 AM
    Contact this user
    You could
     put an EPR valve on the 3 door case but sooner than later you’ll be changing the cond unit.
