The Wall
Forum / THE MAIN WALL / Thermostat help
  • Post a Reply to this Thread
    Thermostat help (3 Posts)
  • Andrew boiler Andrew boiler @ 7:46 AM
    Contact this user
    Thermostat help
    Hi I just got power back 1 this morning and my thermostat says it's 69 I have it set at 68 it's very cold I don't want it to turn it up please help me
  • Gordy Gordy @ 8:34 PM
    Contact this user
    Hmmm
    How long was the power off?
    What type of heating? Hot water? Steam?
    Do you have Radiators? Or radiant Heat?
    Was 69 comfortable before, and always your t stat setting?
  • Jamie Hall Jamie Hall @ 9:30 PM
    Contact this user
    And an obvious question...
    is the boiler running?  Does it run if you turn up the thermostat?
    If not, what was the power problem?  Is there a manual reset required on the boiler?  Did it lock out for some reason (if oil, did the burner lose prime, for instance?).  Was there a surge along with the power outage?  If there was, did it fry something?
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
