The Wall
Forum / THE MAIN WALL / Need feedback
  • Post a Reply to this Thread
    Need feedback (5 Posts)
  • Andrew boiler Andrew boiler @ 8:25 AM
    Contact this user
    Need feedback
    I have. A thermostat is set at 68 how often will it call for heat like every hour?
    If I am not home what should I set it to?
  • Timco Timco @ 8:36 AM
    Contact this user
    Heat loss
    How often your system calls for heat is directly based on the heat loss of your home, or how well insulated your home is. If not well insulated or old with single pane glass, it will loose heat faster and run far more often.
    Don't set stat back more than 10*.
    Working on steam and hot-water systems isn't rocket science....it's actually much harder.
  • Andrew boiler Andrew boiler @ 8:50 AM
    Contact this user
    Update
    My master bedroom has it's own zone and it's a big room.
    What should I set my thermostat to?
  • Ron Jr. Ron Jr. @ 10:37 AM
    Contact this user
    Set it
    to what you're comfortable with . Mine is at 65 when I'm home . 75 if the girls are home !
  • Gordy Gordy @ 1:07 PM
    Contact this user
    Thermostat
    Swing plays into this, or anticipator setting depending on what kind of thermostat.
    If it's a modern one the swing adjustment is what determines how many degrees below set point the heat call . The lower the swing number the tighter the tolerance to set point. The higher the swing adjustment number the more tolerance above and below set point before the boiler fires.
