The Wall
Forum / THE MAIN WALL / nest thermostat
  • Post a Reply to this Thread
    nest thermostat (3 Posts)
  • Andrew boiler Andrew boiler @ 7:00 PM
    Contact this user
    nest thermostat
    is the Nest thermostat will work with just one zone?
  • Zman Zman @ 7:38 PM
    Contact this user
    Switch
    Yes , the nest will work with a single zone system.
    Most thermostats are simple switches. When the temp gets to the set temp they close the circuit. The nest is supposed to track your habits and adjust automatically. It is still just closing a circuit nothing else.
    Carol Fey has some great books on controls in the Heating Help Store.
    Carl
  • Timco Timco @ 8:16 PM
    Contact this user
    Nest
    It's not always compatible. Will not just hook to a Triangle. Had to install a relay and transformer to get constant voltage.
    Working on steam and hot-water systems isn't rocket science....it's actually much harder.
