The Wall
Forum / THE MAIN WALL / How Thermostat works
  • Post a Reply to this Thread
    How Thermostat works (6 Posts)
  • Andrew boiler Andrew boiler @ 12:37 PM
    Contact this user
    How does a thermostat works if I have it at 68 will it come on when it's below 68?
    I have a Honywell thermostat no idea hot to check it I need help
  • SWEI SWEI @ 12:39 PM
    Contact this user
    On and off
    is all a conventional thermostat can manage.  Look for a setting called swing, which determines how far above and below the setpoint the stat will wait before it turns on or off.
  • heatman101 heatman101 @ 12:50 PM
    Contact this user
    More info would be helpful...
    What is the t-stat doing now???
    What is the model number of the t-stat?
    By knowing these things we can help you possibly fine tune the t-stat to work more like you want it to...
  • Andrew boiler Andrew boiler @ 1:47 PM
    Contact this user
    How thermostat
    My thermostat is a Honeywell TH1100D1001
    Don't know that much about it
  • heatman101 heatman101 @ 2:09 PM
    Contact this user
    +/-1
    That is what your t-stat is supposed to hold.It may take a few days to get there.
    You also may be able to change the cycles setting. Check the attached installation manual for instructions for doing that.
    http://s3.pexsupply.com/product_files/TH1100D,TH1110D,TH1210D,TH2110D,TH2210DInstall4.pdf
  • VA_Bear VA_Bear @ 3:52 PM
    Contact this user
    Where did you find the +/-1 deg spec?
    Honeywell's manual and website do not specify the swing and electronic thermostats can vary from +/-0.5 to +/- 2 degrees.
    VABear
    This post was edited by an admin on October 27, 2013 3:55 PM.
