The Wall
Forum / THE MAIN WALL / Radiant Floor Question
  • Post a Reply to this Thread
    Radiant Floor Question (2 Posts)
  • ONETEE ONETEE @ 3:59 PM
    Contact this user
    I am at the end of a renovation and planning to retrofit radiant heat under an 3/4" oak floor (with 3/4" sub). My HVAC friend was able to get me left over 5/8" Wirsbo hePex. I know it is meant primarily for concrete use and not necessarily for staple up, which is what I am going to do. I bought 1/2" heat transfer plates a year ago in preparation that I could sell if I don't use them. Here's my question....... do I hang the 5/8" pex or do I stick with the original plan and go out and purchase the 1/2" pex? My buddy did mention that he has friend that makes transfer plates, but I was simply going to hang them.
    Thanks
  • SWEI SWEI @ 4:15 PM
    Contact this user
    Plates and tubing
    Assuming it's actually 5/8" hePEX, I do not know of any plates which will fit it.  Anything which is made up will almost certainly be a U-plate rather than a C-plate (aka Omega plate) and would work well only if installed underneath the wood flooring, before it is installed.  1/2" barrier tubing will cost less than new plates anyway.
    What kind of plates do you have?
