The Wall
Forum / THE MAIN WALL / Off Topic Firewood over state lines
  • Post a Reply to this Thread
    Off Topic Firewood over state lines (4 Posts)
  • billyL billyL @ 1:58 PM
    Contact this user
    I'm live in NH and want to bring firewood to Mass. Is this agaist the law? I think Maine has a rule about this but do not know about Mass. Thanks in advance
  • Jamie Hall Jamie Hall @ 4:19 PM
    Contact this user
    Please don't
    I'm not absolutely sure about whether there is a law about wood from New Hampshire to Massachusetts.  If there isn't...
    But plain common sense should tell you not to even think of doing it.  There are several pests -- nifty little bugs -- which travel very happily on firewood from place to place.  Some of them -- such as the emerald ash borer -- are sufficiently nasty as to kill every single ash tree where they arrive, and then spread.
    There is ample local firewood in Massachusetts (or any New England state, for that matter) to supply all you might every need, without the risk of importing problems from somewhere else.
    So please, please, just don't do it.
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
  • vaporvac vaporvac @ 4:26 PM
    Contact this user
    County lines, too!
    Sometimes those restrictions apply to county lines, so check that out as well.
  • MDNLansing MDNLansing @ 10:29 PM
    Contact this user
    Read about
    what's happened in Michigan between the Upper and Lower Peninsulas. In particular the emerald ash borer and gypsy moth have caused big problems here. Previous poster is 100% correct. It's not good to do it. Law or no law.
