The Wall
Forum / THE MAIN WALL / Biasi boiler
  • Post a Reply to this Thread
    Biasi boiler (2 Posts)
  • Marilyn Marilyn @ 7:45 AM
    Contact this user
    Biasi boiler
    Are these boilers positive pressure?
    The cleaning ports are on the front. Are there any other vents to vac that I may be missing?
    Marilyn
  • earl burnermann earl burnermann @ 8:41 AM
    Contact this user
    Biasi
    Yes, this boiler is positive pressure. There are passageways between the combustion chamber and heat exchanger that may need to be cleaned. I've only cleaned them out once on a boiler that had clogged with soot. My Biasi is about nine years old and I have never needed to do this. I clean the combustion chamber every time I clean the boiler though
    If the women don't find you handsome, they should at least find you handy!
