The Wall
Forum / THE MAIN WALL / need a little information
  • Post a Reply to this Thread
    need a little information (8 Posts)
  • N/A @ 8:55 AM
       Hey wet heads this is the ole man from deep south and I need a little information
     I am laid up and trying to help out a friend. He has a heat maker model 130HWNAT boiler and I need to make sure of the size he has a little over 4000 sq ft and the unit has heated the building quite well when it works, but for the last few years it has given them a ton of problems and want me to replace the boiler. I cant leave the house because of my medical problems but they want me to install them a new boiler and I just want to make sure of the size so I can g a head and order one. Any help would be great6ly appreciated.
    PEACE BE WITH YOU
    David C. Broome
    PS I think its a 130k BTU but not sure if that's input or output
    This post was edited by an admin on December 1, 2013 8:56 AM.
  • Heatmaker
    Start with heat loss calc's for the house. If it's anywhere between 80 and 120,000 BTU's, my choice would be a Prestige Excellence as long as they would be happy with 3.5 GPM of DHW. If they need more, use a Prestige Solo Trimax with whatever size indirect is suitable.
    Often wrong, never in doubt.
  • Rich Rich @ 10:03 AM
    Contact this user
    HTP
    Versa Flame  or Versa Hydro . Flame is a boiler with  Plate HX for DHW , 130K will easily do 3.2GPM . Versa Hydro is a water heater with 100 K Space heating capability . Both are comparably priced with the heatmaker .  Hope all goes well .
    You didn't get what you didn't pay for and it will never be what you thought it would
  • Mark Eatherton Mark Eatherton @ 10:56 AM
    Contact this user
    The math works out
    To 22 btu per square foot per hour. Can't tell you if it's right or wrong without a loss calc, but it sounds reasonable for here in Denver.
    Get well soon big guy.
    ME
    It's not so much a case of "You got what you paid for", as it is a matter of "You DIDN'T get what you DIDN'T pay for, and you're NOT going to get what you thought you were in the way of comfort". Borrowed from Heatboy.
  • N/A @ 3:04 PM
    Hi Mark
    Hope all is well wit your clan. I just can't physically drive back over to the job-site for a few days and just wanted to make sure of he old boiler size. I am going with a tank-less water heater and a separate boiler. The old boiler heated very well and did a good job from what the homeowner stated until it started to fall apart a few years ago and the owner just wanted it replaced. As I stated it is a heat-maker model # 130 hw nat. Just not that familiar with that unit. Lol Plus the perkacet and loratab not making it real easy to think real straight but works good on the pain .
    Peace Be With You
    David C. Broome
  • Weezbo Weezbo @ 3:17 PM
    Contact this user
    the jelly beans
    the Dr's have us eat after an operation do funny stuff like when your feet take off in some other direction while walking... i was like
    ' Hey ! come back here you ! '
    i ate a plastic fork tine while hammering down some New York steak on sale at 50 percent off and 50 % off of that price at like 2 a.m.
    16000 $ later...
    they hadn't found the tine buh assured me i didn't have cancer lol..
    man that hurts when i think about it any way , speedy recovery and steer away from stairs lol.. because them sideways pills or whatever they are are Brutal.!!
  • Mark Eatherton Mark Eatherton @ 4:46 PM
    Contact this user
    David...
    you obviously don't have the time to do a proper heat load calculation. For the sake of time and simplicity (also based on customer feedback) lets assume a proper one was done. At a minimum, I would ask the customer to measure up the connected baseboard, then assume 500 btuH/linear foot, then add for the efficiency of the appliance you are using (82, 86 or 95%) and use that as a sizing guide.
    As others have asked, was it also doing DHW or any other loads? If yes, it may have been oversized for the DHW load, which in your part of the country os probably the bigger of the two loads.
    ME
  • Techman Techman @ 11:35 AM
    Contact this user
    need a little
    Good Morning to you David. How  did the boiler work OK for X amount of years ,and then not so good for the past couple of years? Just mechanical problems?
    This post was edited by an admin on December 1, 2013 11:36 AM.
