The Wall
Forum / THE MAIN WALL / Watts 'HAV' automatic radiator bleed valve?
  • Post a Reply to this Thread
    Watts 'HAV' automatic radiator bleed valve? (2 Posts)
  • Nom_Deplume Nom_Deplume @ 2:35 PM
    Contact this user
    Any actual experience with this valve? They bleed air when dry and shut off when the material in it gets wet and swells. So they can be installed on radiators in any orientation.
    Do they work well for years, or do they leak or stop working?
    I just installed one on a Runtal baseboard that was slowly collecting air and then becoming noisy. It was almost magical: I opened the shutoff valve in the basement, and by the time I got to the 1st floor the baseboard (previously drained to install bleed valve)  was full of water and yet the bleed valve hadn't spewed any water. But I don't know about the long term.
    This post was edited by an admin on December 3, 2013 2:49 PM.
  • hot rod hot rod @ 3:57 PM
    Contact this user
    depends on how often
    it goes dry/ wet. Typically once they vent air they shut down unless the system is drained down. Or sometimes first start up in the fall they will vent and seal.
    Some brands have a built in ball check so the end can be completely removed, replaced or removed to prevent theft or damage.
