The Wall
Forum / THE MAIN WALL / low and high water temp setting
  • Post a Reply to this Thread
    low and high water temp setting (4 Posts)
  • eastvillage eastvillage @ 2:39 PM
    Contact this user
    hi, i have a burnham v7 boiler with the hot water coil. i have the water temp set at 160 and 180. i'm away during the week so i set the themostat at 50. i was wondering what the best setting for the hi and low should be when i'm not there and don't need any hot water.
  • billtwocase billtwocase @ 7:05 PM
    Contact this user
    set LO
    all the way down, about 100 degrees. When the thermostat call for heat, it will heat to the HI setting-180 degrees. If no one will need hot water, you will be OK and save a couple of bucks
  • eastvillage eastvillage @ 4:38 PM
    Contact this user
    thanks
    thanks
  • Paul48 Paul48 @ 10:31 PM
    Contact this user
    LOW
    His lo-limit setting may be the only thing protecting his boiler from flue gas condensation.
