The Wall
Forum / Oil Heating / Oil burner blower
  • Post a Reply to this Thread
    Oil burner blower (4 Posts)
  • TheMezz TheMezz @ 1:16 PM
    Contact this user
    Oil burner blower
    Our oil burner turns on then off. Ten seconds later the blower comes on again for about a minute. It happens like that each time.
    It used to just come on then the blower woks stay on without that interruption
    Suggestions ?
  • earl burnermann earl burnermann @ 3:18 PM
    Contact this user
    blower comes back on
    Although the call for heat has ended and the burner has turned off there is still heat in the combustion chamber that is re-heating the heat exchanger. If you have the mechanical type fan limit switch then when the temperature gets hot enough the fan switch reactivates and purges the heat out of the system.
    Check to make sure your filter is clean, that your vents are open, and that no one has blocked any of them with, maybe, a Christmas tree and gifts.
    If the women don't find you handsome, they should at least find you handy!
    This post was edited by an admin on December 25, 2013 3:19 PM.
  • TheMezz TheMezz @ 9:52 AM
    Contact this user
    vent is clear and filter is new...
  • Weezbo Weezbo @ 3:08 PM
    Contact this user
    is this an older burner?
    could this be a belt driven model ? how about a picture of the burner or a model or manufacturers name of the burner.
    hard to sometimes think just where to start because not all burners are made the same.
    thanks...
