The Wall
Forum / Domestic Hot Water / Rinnai Continuum 2520 help
  • Post a Reply to this Thread
    Rinnai Continuum 2520 help (2 Posts)
  • Jackster8 Jackster8 @ 3:12 PM
    Contact this user
    Hello,
    I have an issue that is stumping my installer and levelĀ 2/3 tech. I also contacted Rinnai.
    I have this unit for about 7 years and have had 5.5 great years with it. The last 1.5 years though I have had a decrease in my water temp to 103-5 degrees at best (i measured with a thermoter). sometimes it pulses to colder than that. I have very sporatic moments of normal 120 degrees - once every couple of weeks perhaps.
    I have hard water and iron riich. I have a softener and Acid nuetralizer on the well supply to my home. I do get some rust (iron) sediment build up on occasion. I've flushed the system, cleaned the barrel screen on the water inlet and had two service techs in to take a look at it. #1 the installer and #2 the level 2/3 tech. The second of the two recent suggested it may be my flow sensors. I managed to find the one on the top right and that looks normal.
    Anyone have any suggestions? My level 2/3 guy is very busy and not anywhere near my location so it is hard for him to get to us.
    Thanks
    Jack
  • Snowmelt Snowmelt @ 11:33 PM
    Contact this user
    Code
    What code are you getting, does the thermistors need to be cleaned or swapped out. Do you have a gas meter to check gas pressure. What did the tech say?
