The Wall
Forum / Controls / Burner regulation
  • Post a Reply to this Thread
    Burner regulation (5 Posts)
  • nicholas bonham-carter nicholas bonham-carter @ 9:22 AM
    Contact this user
    Burner regulation
    Could a burner be adjusted by analysis of its sound of combustion (like tuning motorcycle engines in the old days)?
    A computer could analyse the sound and make changes in the mixture as an ongoing process, for clean burning.--NBC
  • Jamie Hall Jamie Hall @ 1:23 PM
    Contact this user
    I used to do a pretty decent job
    tuning my muscle car that way... ('66 Buick Gran Sport, Stage II)!
    The idea I've thought of is similar -- although a little more 21st century.  Why not use an oxygen sensor (yeah, I know they are expensive) on the stack?  Seems to me that one could do that, and probably be able -- with a little computer hardware and some servos -- to get a pretty decent turn down on either oil or gas that way.
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
  • SWEI SWEI @ 2:19 PM
    Contact this user
    O2 sensor on the stack
    aka lambda control, is relatively common on large BTU burners in restrictive jurisdictions (SCAQMD comes to mind.)  Viessmann also does it on all their current gas burners.
  • JStar JStar @ 8:12 PM
    Contact this user
    Viessmann
    Is that why you can't field adjust them? Only worked on one in the last year. Too few to know the little quirks.
    - Joe Starosielec
    http://thatcherhvac
    http://facebook.com/thatcherhvac
    Guaranteed performance. Guaranteed energy savings.
    Serving all of NJ, NYC, Southern NY State, and eastern PA.
    Consultation anywhere.
    (Formerly "ecuacool")
  • Chris Chris @ 10:11 PM
    Contact this user
    No Need To Adjust
    With Lamda on Vitodens, the boiler is able to adjust gas independent of air. It will always burn clean. Has to. If combustion came out of the range, burner would shut down. Here is the other thing that is missed when it comes to Lamda. CONDENSING!!!!!!!
    If have Vitodens out there pouring at 160 supply. Why, lamda...
    "The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."
