The Wall
Forum / Radiant Heating / Thinking of replacing existing pump for a Taco Bumble bee pump
  • Post a Reply to this Thread
    Thinking of replacing existing pump for a Taco Bumble bee pump (10 Posts)
  • Total1 Total1 @ 5:26 PM
    Contact this user
    Thinking of replacing existing pump for a Taco Bumble bee pump .
    https://www.taco-hvac.com/en/products/products.html?current_category=405
    On my Vitodens 100 system .
    Ideas ?
  • Harvey Ramer Harvey Ramer @ 8:10 PM
    Contact this user
    Why?
    Why?
  • delta T delta T @ 9:14 PM
    Contact this user
    Looks like a...
    WIlo you have installed. Very good pump, pretty much all I use. I second the question...Why? do you have any problems with system?
  • Total1 Total1 @ 10:35 PM
    Contact this user
    Like the idea of the pump
    Like the idea of the pump adjusting to the boiler temperature and keeping the delta T the same .  No problems at all with the system , but the new pump would use 85 % less power and has a cool look factor ..
  • Tom Tom @ 6:18 AM
    Contact this user
    and noisy
    The bumble bee is much louder than normal pumps. If thats a factor.
  • Chris Chris @ 7:36 AM
    Contact this user
    WOW
    LWCO is in the wrong place though it doesn't matter because the boiler won't fire anyway if you don't make the flow switch..With the boiler needing a min flow rate of 1.7gpm across the HX and you are not piped pri/sec wouldn't recommend it unless your going to run it in a constant pressure mode.
    What's with that zone valve and the ball valve? Some sort of by-pass?
    "The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."
    This post was edited by an admin on January 31, 2014 7:37 AM.
  • Total1 Total1 @ 8:44 AM
    Contact this user
    hmm
    Why is the LWCO in the wrong place ? It is the highest in the loop  , where would you put it ?  .  The zone valve / bypass is for the room / tunnel under the garage to get enough flow to start the boiler .
  • Chris Chris @ 9:27 AM
    Contact this user
    huh?
    That's why the boiler should have been properly piped primary secondary. Sure hope you never need more then 6.2gpm...LWCO is useless so it doesn't matter...
  • NYplumber NYplumber @ 10:36 AM
    Contact this user
    Dont mess
    Dont mess with a high head hx and dt. If you slow the flow too much you will loose more then you gain.
    :NYplumber:
  • Total1 Total1 @ 4:43 PM
    Contact this user
    ok
    With this on demand boiler , since it keeps no water warm when it shuts off , and the pump is controlled by the boiler also  , I have no need to circulate the water when it is off . The Gas inspector wanted a LWCO installed , I even quizzed him on why one is needed with the flow switch . This boiler is ONLY heating my garage , room / tunnel below the garage , and later project floor heat for the bathroom in the basement , all is good and thanks for your input . I will keep it how it is . To keep around 1100 sq ft of floor heated it averaged out to be 1 $ per day @ 60 F , even when it was -36 C .
