The Wall
Forum / A-C, Heat Pumps & Refrigeration / Looking for residential installer in Denver, Colorado
  • Post a Reply to this Thread
    Looking for residential installer in Denver, Colorado (4 Posts)
  • thermos thermos @ 10:12 PM
    Contact this user
    I'm looking for an experienced HVAC installer in the Denver, Colorado area. I'm looking to replace a gas boiler serving baseboard radiators with a Daikin Altherma or similar air-to-water heat pump product. Ideally the installer would be familiar with Daikin products and controls.
    Thanks.
  • This post has been deleted!
    This post was deleted by an admin on April 9, 2014 8:38 AM.
  • RJ RJ @ 9:47 AM
    Contact this user
    hvac contractor
    Pasterkamp  Heating or AMS mechanical
    RJ
  • Mark Eatherton Mark Eatherton @ 9:50 AM
    Contact this user
    Start with the Daikin rep...
    Shamrock Sales, three zero three-399-9181
    Are you absolutely sure it will work? There are limitations on the temperature output of these ASHP systems that may not be compatible with your system design. Baseboard is typically designed around a 180 degree F average temperature.
    ME
    It's not so much a case of "You got what you paid for", as it is a matter of "You DIDN'T get what you DIDN'T pay for, and you're NOT going to get what you thought you were in the way of comfort". Borrowed from Heatboy.
  • don don @ 5:32 PM
    Contact this user
    Limits
    I agree with Mark the highest I want to push one would be 125 degree max.Anything over that in you are going to reduce the life of the equipment very quickly.
