The Wall
Forum / Strictly Steam / Kickstart THIS!
  • Post a Reply to this Thread
    Kickstart THIS! (17 Posts)
  • Eastman Eastman @ 5:55 PM
    Contact this user
    Kickstart THIS!
    I'm curious to hear what other ideas people would consider supporting via crowd funding. Smart vents that ensure balance? Variable EDR radiator valves? ???
    What's missing from modern steam?
    This post was edited by an admin on February 15, 2014 5:57 PM.
  • MarkS MarkS @ 7:37 PM
    Contact this user
    How about
    an affordable outdoor reset control for single-family residential steam?
    It's coming. Anyone interested?
    Homeowner, Royersford PA | 1890 one-pipe steam system | 3009 sf | 3 floors | 14 radiators | Utica SFE5200S boiler
    Midco LNB-250 Modulating Gas Burner | EcoSteam modulating controls | 70 to 300 MBH |
    607 sf EDR connected load | Operating pressure: 0.5 oz/in2
    Four main runs (insulated) totaling 135 ft in length | All Gorton vents on mains & rads |
    A Steam Odyssey | Odyssey 2 | Odyssey 2014 | A Steam Enthusiast's Outdoor Reset Control
  • Eastman Eastman @ 8:00 PM
    Contact this user
    The alternatives
    are quite expensive?
  • MarkS MarkS @ 8:16 PM
    Contact this user
    Quite
    The outdoor reset controls currently available for steam are targeted towards commercial and multi-family buildings rather than the residential market. They're a bit pricey for the individual homeowner.
    In principle, there's no reason that outdoor reset shouldn't work on smaller systems. And in practice, the outdoor reset control on my residential system has been operating successfully for a couple of years now (even before the Midco burner).
  • nicholas bonham-carter nicholas bonham-carter @ 11:17 PM
    Contact this user
    I'm ready
    Also, could your control system be adapted to a hot water boiler, for a wider audience?--NBC
  • MarkS MarkS @ 7:18 AM
    Contact this user
    Hot Water
    It could, but there's a much wider selection of ODR systems out there for hot water, so it's probably not worthwhile to try to compete in that market space.
  • Joe V Joe V @ 8:12 PM
    Contact this user
    what's missing from modern steam?
    Knowledge, of course! that's why we come here.
    actually, I believe steam has plateued because the market is shrinking. A 90%+ efficient boiler maybe?
  • ChrisJ ChrisJ @ 10:47 PM
    Contact this user
    Fix that
    How can you make the market grow?
    How can you make a steam system that will compete with other cheaper systems?
    You would think a system with almost no moving parts, no pumps, no fans, could be made to be cheaper then forced hot air, some how.
    I'm all for an outdoor reset for systems like mine.
    Weil-McLain EG-45 connected to 392sqft of radiation via two 2" risers into a 3" drop header and 2" equalizer. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
    Steam system pictures updated 6/5/14.
    https://picasaweb.google.com/thetube0a3/Boiler?authkey=Gv1sRgCImUxIqv9436MQ#
  • Steamhead Steamhead @ 12:19 AM
    Contact this user
    Here's one possibility
    http://www.heatinghelp.com/forum-thread/131555/New-steam-mini-tube-system-installed-in-my-own-house-Iron-Fireman-style
  • Joe V Joe V @ 8:45 PM
    Contact this user
    well that microsteam system certainly sounds intriguing
    I dont know how I missed that thread.
    This post was edited by an admin on February 16, 2014 8:47 PM.
  • JStar JStar @ 10:55 PM
    Contact this user
    ODR
    Mark, I think we have a great candidate in ChrisJ for a launch prototype! He lives a few towns over from me, so callbacks won't be brutal.
    - Joe Starosielec
    732-494-4357
    j.star@thatcherhvac.com
    http://thatcherhvac
    http://facebook.com/thatcherhvac
    Guaranteed performance. Guaranteed energy savings.
    Serving all of NJ, NYC, Southern NY State, and eastern PA.
    Consultation anywhere.
    (Formerly "ecuacool")
  • ChrisJ ChrisJ @ 10:59 PM
    Contact this user
    Absolutely
    I'd be glad to be a test subject if the opportunity ever presents it self.
  • MarkS MarkS @ 8:15 AM
    Contact this user
    Test subject
    That's great, ChrisJ, thanks. I'll put you on the list of potential beta testers.
  • gerry gill gerry gill @ 9:33 PM
    Contact this user
    a code approved
    millivolt gas valve would be nice..steam boilers could be rated at higher efficiency i would think if they also used no electricity.
  • gerry gill gerry gill @ 9:36 PM
    Contact this user
    The return of the
    Hoffman #10 main vent would also be nice..the only thing venting faster than that was an open 1/2'' pipe.
  • Eastman Eastman @ 11:53 AM
    Contact this user
    3/4 inch mains
    I'm looking back through the SelectTemp brochures. The technology seems so relevant to today. Is there a design/install manual out there somewhere?
  • Gordo Gordo @ 11:32 PM
    Contact this user
    Things I'd Like to See With Steam
    1) Hi-Lo firing in all size models.
    2) Accurate low pressure transducers in place of pressuretrols or even Vaporstats with direct digital read-outs of actual system pressures.
    3) A high temperature sensor in the flue gas stream to shut down boiler to prevent dry-firing in the event of LWCO failure.
    4) Sightglasses with ALL brass components and proper blow-down valves.
    5) A main vent with twice the venting as a Gorton #2.
    6) An affordable single pipe steam TRV.
    7) 3 small tube cast iron radiators made in the USA.
    8) Affordable firing cycle/outdoor reset t-stat (as others have said above)
    9) Add an O2 sensor in the flue gas stream, combine with the temperature sensor above add a processor (from an I-phone app) and get real time combustion efficiency...
    *sigh*
    Dream on, I guess.
