The Wall
Forum / THE MAIN WALL / Bell and Gossett 100 mystery sounds
  • Post a Reply to this Thread
    Bell and Gossett 100 mystery sounds (12 Posts)
  • MitchInNJ MitchInNJ @ 9:14 PM
    Contact this user
    Hello there, Long time lurker here seeking your expert advice. I had some awful metal scraping sounds coming from my B&G 100 series pump. It's a hot water baseboard system. I checked for the obvious and found a mangled coupler inside. After carefully replacing the coupler and very lightly oiling the 2 motor tubes, and heavily oiling the bearing assembly, I turned the pump back on.
    Now I'm getting a very different grinding sound. Not as loud but still not right. It sounds like there is a piece of metal clanging around in there near the bearing assembly or impeller. I know I pulled the entire coupling out, so it can't be that.
    Am I missing something here fellas?
  • Gordy Gordy @ 9:55 PM
    Contact this user
    Motor mounts
    You should replace the mounts with the coupling. If you don't the coupling will fail prematurely due to miss alignment from worn mounts. Probably why they failed in the first place.
  • B & G
    The motor mounts may be shot, but they wouldn't be the cause of this new sound so soon. Sometimes a day or two of run time will clear up a dry bearing assembly. Failing that, I'd:
    1) check to make sure the coupling assembly was installed properly
    2) de-pressurize the system and check the impeller for debris.
    Often wrong, never in doubt.
  • Dan Holohan Dan Holohan @ 3:01 PM
    Contact this user
    Oil
    Are you using 20-weight, non-detergent oil? Did you check the wicking to see if it's burnt? Did you press the wicking onto the bearing with the back end of a pencil?
    Site Administrator
    dan@heatinghelp.com
    Hug your kids.
  • MitchInNJ MitchInNJ @ 10:28 PM
    Contact this user
    B and G
    @ Gordy. Yes. I will replace the motor mounts next for good measure.
    @ Alan. I rechecked the coupler to make sure the set screws were recessed and they were. Are you saying it's ok to run the motor with that sound for a day and see if it goes away?
    @Dan Yes. I'm using read deal B&G 20 wt oil in the little clear tube. The cotton is in perfect shape in the oil chamber and I probably poured a half tube in there... so much it dripped out the bottom. I will push the wick down onto the ball bearing as you suggested...Could this clangy sound come from an under oiled bearing? It sounds like somebody left a quarter in the dryer.
    Thank you all for your comments gentlemen.
  • Dan Holohan Dan Holohan @ 7:52 AM
    Contact this user
    Is the sound constant?
    Or intermittent?
    Site Administrator
    dan@heatinghelp.com
    Hug your kids.
  • billtwocase billtwocase @ 4:32 PM
    Contact this user
    coupling
    If you have a Sids close by, pick up a 156A spiralink coupling. You also should not need to replace the motor mounts if you use it. You will know if it is over oiled, it will leak out. Don't be afraid to put the oil to it
  • MitchInNJ MitchInNJ @ 11:56 AM
    Contact this user
    Bell and gossett mystery sounds
    Thanks for the replys. I've now checked and replaced the coupler twice, including the motor mounts, and oiled the chamber utility it leaked out the bottom., but I still have a clanging comming from the bearing assembly.
    What do I do next? Could something be clanging around in the impeller? How can a broken coupler lead to a broken impeller?
    This post was edited by an admin on March 2, 2014 11:57 AM.
  • icesailor icesailor @ 12:15 PM
    Contact this user
    Noise:
    New Series 100 circulators have a plastic impellor.
    Very old ones have multi piece metal ones. I've seen them fall apart.
    That isn't saying what your problem is.
    A few years ago, I had a noisy  007 that had been quiet for years. I pulled out the guts and there was a big goober of solder that had flowed onto the volute and the impellor was rubbing on it.
    You never know what it might be,
  • Big Ed Big Ed @ 1:04 PM
    Contact this user
    Motor Bearings
    Was there a large in and out movement on the motor shaft ? Did you aline
    coupling so alan screw tighten into counter sink ? Big you bang on the coulping to fit it on the shaft ?
    I have enough experience to know , that I dont know it all
    This post was edited by an admin on March 2, 2014 1:12 PM.
  • MitchInNJ MitchInNJ @ 1:38 PM
    Contact this user
    B and g mystery sounds
    @ big ed. I wiggled the coupling on to both shafts making sure the set screws got "sucked" Into the countersinks. Backed it out several times until if got it right.
    I didn't check the shaft for in and out movement. Should I? How far in or out should it be? Does this matter?
  • Steve Ebels Steve Ebels @ 3:03 PM
    Contact this user
    Just a thought
    Instead of wrestling with the old pump you could just take it out and replace it with a modern wet rotor design.
    A BnG NRF22 or Taco 007 are nearly direct replacements from a hydronic standpoint and the flange dimensions are identical.
    In a Grundfos you could select a 15-58 3 speed or a 15-55 Alpha variable speed which will use 60-80% less power and will auto adapt to your systems flow characteristics.
    A Wilo 21 series 3 speed will do the same as the Grundfos 15-58.
    All of these will use less power than the BnG 100 by at least 25%.
    Just a thought.
