The Wall
Forum / THE MAIN WALL / Underground Insulated Pex
  • Post a Reply to this Thread
    Underground Insulated Pex (7 Posts)
  • Harvey Ramer Harvey Ramer @ 6:46 PM
    Contact this user
    What is everybody using these days when it comes to direct burial insulated pex? I'd like something readily available. Eco Flex would be nice but i'm not aware of anybody in the area 17241 or nearby radius that carries it.
    Harvey
  • Paul Pollets Paul Pollets @ 7:43 PM
    Contact this user
    Ecoflex
    Ecoflex is available with a 10-14 day order lag from any Uponor wholesaler. There is a cut charge for orders less that a full roll. Just buried some 3 weeks ago.
  • hot rod hot rod @ 9:39 PM
    Contact this user
    also
    Watts Radiant and Rovanco
    http://www.rovanco.com/flexible-pipe.html
  • Harvey Ramer Harvey Ramer @ 6:30 PM
    Contact this user
    Thanks Guys
    I guess I'll have to order and wait. Not a big deal but not what I prefer.
    Harvey
  • Larry Weingarten Larry Weingarten @ 1:11 AM
    Contact this user
    Harvey, I've installed...
    ... long lengths of insulated PEX by using PVC conduit and pulling the insulated tube through the conduit.  I don't know how it compares price-wise, but it works.  Just make sure the conduit ID is enough bigger than the OD of the insulation so there is good working room and low friction.
    Yours,  Larry
  • hot rod hot rod @ 9:48 AM
    Contact this user
    Insul-Seal
    is another product I have used. Glue the sections together and slide whatever tube you like inside. Include wires and water fill lines also.
    With InsulSeal you can remove and replace the tube if needed
  • Ironman Ironman @ 9:57 AM
    Contact this user
    Insul-Seal
    The only caveat with Insul-seal is that it has no flexibility at all. Even less than bare PVC because of the polyurethane coating. They do have pre-made fittings for it, but trying to improvise your own with electrical sweep fittings can be real fun since the PVC in the Insul-Seal is SDR22, not schedule 40.
    Don't even ask me how I know this. :(
    Bob Boan
    This post was edited by an admin on February 26, 2014 9:59 AM.
