The Wall
Forum / Gas Heating / Janitrol Automatic pilot
  • Post a Reply to this Thread
    Janitrol Automatic pilot (4 Posts)
  • DPeak DPeak @ 2:27 PM
    Contact this user
    Our very old hot water system has a pilot control made by Janitrol/Surface Combustion. It sends an electrical signal confirming the pilot is lit to a controller that opens the gas valve. The type designation is X O. It has apparently died, as bypassing it allows the boiler to fire. See picture attached.
    Anybody know if there is a modern replacement part available? Or if there are any originals floating around?
  • unclejohn unclejohn @ 10:38 PM
    Contact this user
    Does it
    Have a thermocouple attached to it? If it does you can still get a BASO control.
  • Tim McElwain Tim McElwain @ 8:45 PM
    Contact this user
    That pilot is obsolete and
    no longer available. You would have to d a complete changeover which is not cheap and requires someone with experience at doing such things. Sound like it is time to replace the old boiler.
  • DPeak DPeak @ 5:25 PM
    Contact this user
    Thanks
    Thanks, I appreciate the input. I assumed that would be the case, so we are already moving that direction. Sure hate to see the old boiler go, it had a good long run.
