The Wall
Forum / Gas Heating / Reducing mod/com output with multiple stage gas valve
  • Post a Reply to this Thread
    Reducing mod/com output with multiple stage gas valve (9 Posts)
  • BigRob BigRob @ 12:11 AM
    Contact this user
    I need to serve some 6k loads and am exploring options. Has anyone experimented with this? I suspect it would run pretty lean.
  • SWEI SWEI @ 12:21 AM
    Contact this user
    Wouldn't even think of it
    violates pretty much every listing the boiler has and would expose me to unfathomable liability.  For loads that small, we use modulating electric resistance boilers.
  • BigRob BigRob @ 12:35 AM
    Contact this user
    Yeah
    I immediately regretted posting this. Why don't they offer more aggressive turn down in residential products? Multiple small fire tubes would be interesting.
  • SWEI SWEI @ 10:01 AM
    Contact this user
    More turndown
    comes with more problems maintaining clean, efficient combustion.  Or has on existing burner designs.  http://www.sermeta.com/en/product/bluejet-burner/ has the potential to change the game.
  • BigRob BigRob @ 11:17 AM
    Contact this user
    Pressure balanced
    What makes this high performance? Is each orifice pressure balanced for equal output? The pictures show a nice flame for sure.
  • Jack Jack @ 2:15 AM
    Contact this user
    You might look at
    The Rinnai Energysavers. Model EX 08 will modulate from 3-8 kbtu.
  • Tim McElwain Tim McElwain @ 9:18 PM
    Contact this user
    There are no negative pressure
    gas valves that are what I would call multi stage in the real sense as the turn down ratios are defined by how low the firing rate can go based on burner design and port loading with the varying speed of the inducer. This falls under a standard which has not been changed here in the US, at least not to my knowledge. It has to do with the minimum firing rate for safe ignition based on using flame rectification as a flame proving system.
  • Eastman Eastman @ 2:33 PM
    Contact this user
    bluejet
    3400 btu minimum with 40 to 1 mod rate is excellent. combi boilers should make great use of this if the technology pans out.
  • clammy clammy @ 8:43 AM
    Contact this user
    nice upgrade burner
    just wondering if these burners could be used as a replacement for giaconni based boiler older munchkins /purefires .wondering how they would perform as compared to the mesh screen burners being some early mod cons used a stainless burner then upgraded to mesh but those early version where not as jeted as those blue jet are .just thinking out loud peace and good luck clammy
