The Wall
Forum / THE MAIN WALL / tenant heat metering
  • Post a Reply to this Thread
    tenant heat metering (5 Posts)
  • rjncont rjncont @ 1:51 PM
    Contact this user
    what is an accurate means to meter tenant heating from a central heat source (oil boiler)? all units are zoned individually
  • SWEI SWEI @ 2:48 PM
    Contact this user
  • Rich Rich @ 8:33 PM
    Contact this user
    Taco
    Iworx system can be part of the system also because nobody will just take your math at face value .  You will also require a KNOWN Delta T . There are a few choices of circulator that will closely control Delta T . Taco VDT and Bumble Bee , also Wilo Stratos with IR option .
    You didn't get what you didn't pay for and it will never be what you thought it would
    This post was edited by an admin on March 6, 2014 8:35 PM.
  • Big Ed Big Ed @ 9:21 AM
    Contact this user
    Tenants
    We all know the best option is a separate boiler and oil tank
    I have enough experience to know , that I dont know it all
  • maine rick maine rick @ 7:12 PM
    Contact this user
    control
    we use Honeywell AQ control with communicating thermostats. you can set the max temp and check the amount of hours each zone runs. also is outdoor reset ready.
