The Wall
Forum / Controls / indirect aqua stat?
  • Post a Reply to this Thread
    indirect aqua stat? (6 Posts)
  • Eric Eric @ 12:03 PM
    Contact this user
    indirect aqua stat?
    If you have read any of my posts you can see I'm doing a lot to my system. Now I'm still ordering parts and supplies until i have everything to do the job all at once. So the question for today is I'm going to use a Tekmar 420 with the 335 to run my boiler and zone valves, do I need a aqua stat for my SS30 or just a sensor wired into the 420 controller
  • SWEI SWEI @ 1:26 PM
    Contact this user
    Looks like
    the 420 only supports a contact closure for DHW demand and not a tank temp sensor.  Too bad.
  • Eric Eric @ 1:43 PM
    Contact this user
    what to use
    any old aqua stat work or would it be better to use tekmar set point 161 so they can all talk. If i just use the aqua stat will i need a sensor to know my hw temp?
  • SWEI SWEI @ 1:47 PM
    Contact this user
    Any aquastat will work
    if you want a display, it will cost a bit more.  The point of having a sensor wired to the control is that it can far better anticipate demand.
  • Eric Eric @ 2:10 PM
    Contact this user
    Demand
    Short of it is the tekmar set point will give the best performance all around becouse everything in the system will be nt4 and able to share all info. That way its one item on SS tank, less things less trouble.
  • Eric Eric @ 7:14 PM
    Contact this user
    need help with wiring
    At the point of wiring it all together. The Tekmar 161 setpoint is able to communicate on the house network using 4 wires. the manuals don't tell you how to wire it up. it shows how to do an aqua stat or a set point but not a set point to the dhw terminal. can someone that knows tekmar controls tell me how to do the four wires?
