The Wall
Forum / Buy, Sell, Barter / Ornate Cast Iron Radiators
  • Post a Reply to this Thread
    Ornate Cast Iron Radiators (12 Posts)
  • Edbrown Edbrown @ 7:45 AM
    Contact this user
    I have 8 ornate radiators - 3 tube, 9" x 37.5" tall.
    (2) 5 section
    (2) 7 section
    (2) 8 section
    (2) 9 section
    Also have small square 3 tube 3.5" x 25" tall -  12 section
    And a square 6 tube 8" x 31.5" tall.  15 section - 26" long
    Located - near Syracuse Ny - could deliver.  Asking $1100 for the lot or BO - will seperate.
  • Ironman Ironman @ 9:53 AM
    Contact this user
    Nice
    Those are steam only, so you may want to focus on selling to someone renovating a steam system.
    Bob Boan
  • Edbrown Edbrown @ 12:31 PM
    Contact this user
    yes steam
    Yes they are steam, single pipe.  I recently saw a "manifold" being sold that would screw into the single radiator port and allow a supply and return water line to be connected to the port.  The internal portion of the manifold would extend into the radiator and had orfices/jets that would allow hot water circulation inside a typically one pipe/tap radiator.  Cant seem to find the link now..........
  • SWEI SWEI @ 12:33 PM
    Contact this user
  • Edbrown Edbrown @ 12:36 PM
    Contact this user
    converting from steam to hot water
    Here are the manifolds I mentioned.  I have NOT used them.  Talk to the rep, and they seem like they would work.  Quoted them on a job, but did not get it.
    http://www.hydronicalternatives.com/getattachment/16707372-633d-4cff-a1c4-357fcfcaa8ef/Steam-to-Hot-Water-Conversion-Valve.aspx
    Anyone out there use these at all, to convert from single pipe steam to hot water?
  • Charlie from wmass Charlie from wmass @ 10:37 PM
    Contact this user
    you miss undestand the issue
    the tops are not connected across, they are steam only radiators. The valve by oventrop does not make these work on a forced water system.
    cell # 413-841-6726
  • RobG RobG @ 5:21 PM
    Contact this user
    What Charlie said
    Hence the fact that there is no boss in the top to tap a vent, strictly steam.
    Rob
  • Edbrown Edbrown @ 7:16 PM
    Contact this user
    tops
    I am trying to learn - never looked that close at radiators.
    I see mine are "connected" at the top - but looks like just bolted thru the sections.
    I think you are referring to a full push nipple at the top, which would be much bigger.......which would allow the water to circulate at the top of the sections...??
  • Ironman Ironman @ 11:41 PM
    Contact this user
    Top Nipples
    That's correct. Your rads only have bottom nipples and therefore can only be used on steam. The Oventrop valve won't change that. It's purpose is to allow both supply and return to enter from one point so the rad won't have to be tapped from the other end.
    Rads with top nipples are compatible with steam or hot water.
    Bob Boan
  • Edbrown Edbrown @ 9:31 AM
    Contact this user
    thanks
    ironman,
    thanks for the info!!  Im sure it has saved me a lot of agravation in the future!
  • KC_Jones KC_Jones @ 4:02 PM
    Contact this user
    Wish I was closer to Syracuse!
    Those look pretty nice and still have the valves attached!
    Just another homeowner trying to find his way through.
  • Dan Holohan Dan Holohan @ 7:09 AM
    Contact this user
    Pierce
    Very nice! Here are the ratings:
    Site Administrator
    dan@heatinghelp.com
    Hug your kids.
