The Wall
Forum / THE MAIN WALL / Warmboard on slab versus PEX in slab
  • Post a Reply to this Thread
    Warmboard on slab versus PEX in slab (8 Posts)
  • Charlemagne Charlemagne @ 10:50 AM
    Contact this user
    Basement floor will be lowered two feet and gravel bed, insulation, vapor barrier installed. Exterior walls (half height above grade) will be excavated and waterproofed.
    Question: Can/should warmboard be used below grade in lieu of PEX in slab?
    Will in-slab require higher water temp input for slab versus upper floor's Warmboard?
    Will higher temps rule out use of geothermal water to water exchanger and force introduction of auxiliary heat source to generate additional energy required for slab?
  • SWEI SWEI @ 2:25 PM
    Contact this user
    Warmboard
    costs as much or more than pouring a typical 4" slab does.  Adding it to a new slab really makes no sense.  The required water temps for an insulated slab are quite low, and with proper design, they can easily be made to match those of the Warmboard floor above.
    Both will work well with geothermal, solar or other low temperature heat sources.
  • RobG RobG @ 2:39 PM
    Contact this user
    Agree
    I agree totally with SWEI, you are already pouring the slab, it would be a waste of money to put warmboard over it. Just make sure that you insulate under the slab (the more insulation means less heat loss). The only reason not to put the tubing in the slab would be if you have a very high water table. If that were the case I wouldn't bother excavating anyway.
    JMHO,
    Rob
  • alotlikeearl alotlikeearl @ 3:49 PM
    Contact this user
    Insulation
    Don't forget edge insulation!
  • heatpro02920 heatpro02920 @ 6:07 PM
    Contact this user
    in slab
    this is a no brainer if you are already pouring a slab put it in the slab, insulate it correctly and install the pipe correctly and you will have decades of worry free efficient heat...
    Note- I don't like putting wood board on top of cement, I use the roth panels and like the outcome..
  • Gordy Gordy @ 6:16 PM
    Contact this user
    Tighten it up
    Agree with others. One suggestion tighten up the tubing layout. Helps lower water temps a bit.
  • I agree with Gordy
    Close pipe spacing and good insulation will make the slab heat up in a couple of hours, instead of a couple of days.
    Thanks, Bob Gagnon
  • Gordy Gordy @ 12:58 PM
    Contact this user
    I will add
    Since it's geothermal you should be a with in reach with supply temps to the slab. But then we don't know your heat loss to the space. Also keep your loop lengths with in reasonable design lengths depending on the dia pex you use.
