The Wall
Forum / Gas Heating / pipe dope
  • Post a Reply to this Thread
    pipe dope (7 Posts)
  • GTD GTD @ 8:07 PM
    Contact this user
    pipe dope
    What is the best pipe sealant for n.g black pipe. Thanks tom
  • LPGasman LPGasman @ 9:54 PM
    Contact this user
    I like this stuff
    Made by Gasoila
    This post was edited by an admin on March 27, 2014 9:55 PM.
  • heatpro02920 heatpro02920 @ 11:11 PM
    Contact this user
    Tru Blu
    I use for everything but oil lines/tanks/ect and LP, I like leak lock for LP and refrigerant {if needed}.....
    Tru blu is easy to use and stays good in a lot of temps, natural gas and water... they say oil too but I havent had great luck with it and oil...
  • MikeL MikeL @ 8:07 AM
    Contact this user
    inventory control
    We use teflon tape, and Hercules Megalock for all threaded connections.... ........
  • icesailor icesailor @ 10:08 AM
    Contact this user
    Teflon Tape &:
    So do I.
    I ALWAYS use Teflon tape, no matter what. And I've used a lot of MegLoc.  I stopped using it not because it didn't work, but because the liquid always came out first, no matter how much or how often I stirred the can. It would get hard and I never found any product to dilute it with. Then, the brushes would break off in the can. I tried contacting them but they never responded. So, for water pipes and plastic threads I use Rectorseal #100 with Virgin Teflon. Sounds erotic. On gas or oil, I use tape and Rectorseal #5 Gasoila or Blue-Mol. If you get it on your clothes, it never comes off. I used to see a guy around that used a lot of #5. It was all over his clothes. He must have always worn the same work clothes because although they appeared clean, he was almost yellow from the #5 stuck to his shirt and pants. And if you have the cap lose and you put the can in your tool tray and it tips over, it runs all over your tools and you can't get it off. Even PVC cleaner won't take it off. That's nasty
  • Charlie from wmass Charlie from wmass @ 11:44 PM
    Contact this user
    Pro dope
    it is simple and works well for NG iron pipe
    cell # 413-841-6726
  • 4Johnpipe 4Johnpipe @ 7:16 PM
    Contact this user
    Thread Sealant
    Perma Bond...best product I have come across...
    http://www.permabondllc.com/TDS/LH050_TDS.pdf
