The Wall
Forum / Strictly Steam / radiator paint
  • Post a Reply to this Thread
    radiator paint (5 Posts)
  • dabrakeman dabrakeman @ 2:03 PM
    Contact this user
    radiator paint
    Not a novel thread but I am starting a new one because most that I have read seem to indicate no issues with Rustoleum Specialty Metallic in a copper metallic color.  It was beautiful when I painted it in June after sandblasting.  Come winter it temporarily gave off odor with the first heating cycles as expected, but, what was not expected was the slow continuous color change with each cycle.  By January of the first winter it had changed from a brilliant copper color to a muddy brown/gold dingy color.  Paint says it is good to 200F.  could it have been because I did not use a primer?
    I am now contemplating painting another radiator gold using a VHT engine metallic which I intuitively would have more confidence in from a temperature stability standpoint but the color selection is limited.  The gold is "very gold".  I have plenty of standing radiation for the room to spare so I would prefer to stay with a metallic looking finish.  Also would prefer spray because I believe it goes on much smoother and easier particularly in the interior than brushed on.  Any recommendations out there of a suitable metallic gold paint with more of an antique look than the in your face engine paint gold?
  • MarkS MarkS @ 3:29 PM
    Contact this user
    Not gold or metallic but
    during a 2011 remodel we painted four radiators and exposed risers black with Duplicolor engine enamel. Pretty sure we used primer too. After three heating seasons none show any discoloration or paint separation.
    Homeowner, Royersford PA | 1890 one-pipe steam system | 3009 sf | 3 floors | 14 radiators | Utica SFE5200S boiler
    Midco LNB-250 Modulating Gas Burner | EcoSteam modulating controls | 70 to 300 MBH |
    607 sf EDR connected load | Operating pressure: 0.5 oz/in2
    Four main runs (insulated) totaling 135 ft in length | All Gorton vents on mains & rads |
    A Steam Odyssey | Odyssey 2 | Odyssey 2014 | A Steam Enthusiast's Outdoor Reset Control
  • Jamie Hall Jamie Hall @ 4:03 PM
    Contact this user
    The only problem
    with any of the metallics -- copper, gold, silver -- is what is called "emissivity" -- that is, simplistically, amount of heat, in BTU per hour, which a surface at a given temperature will radiate.  We use a nominal figure of 240 BTU/hr at 215 F -- steam temperature -- but that assumes an emissivity around 95%.  Metallic paints will drop that figure to as little as 70% -- even lower, if they are clean and in good condition.  This effectively derates your radiation to that figure -- say 150 BTU/hr or so.
    You can see this effect for yourself if you have an IR thermometer -- aim it at a regular painted surface and then at a metallic painted one which you know are at the same temperature; the metallic one will show a lower temperature, since an IR thermometer doesn't actually measure temperature, but rather energy radiation rate.
    Now then, there are two problems evident with metallic paint.  First, your radiation may wind up undersized for your space.  Second, your boiler may now wind up quite significantly oversized for your radiation.
    Or you may have both problems at once...
    There have been a lot of threads on painting radiators; look around.
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
  • Paul48 Paul48 @ 5:08 PM
    Contact this user
    Ding-Ding!
    Jamie gets the prize! You've selected the one type of paint they say not to use on radiators.
  • dabrakeman dabrakeman @ 7:03 AM
    Contact this user
    emissivity
    As I pointed out in the initial post the radiator I was able to find for this room is slightly oversized as it is.  Some drop in emissivity is tolerable.  I don't think I am the only one of this mind since many of the room radiations were initially setup assuming you have windows cracked to let fresh air in.
    The purpose of this thread was more to assess how color fast various paint types are.  I would not like to see other people experience the negative results that I did.
    By the way, the metallic painted radiator in the upstairs room that discolored still can overheat the room.
