The Wall
Forum / Gas Heating / Draft Hood
  • Post a Reply to this Thread
    Draft Hood (3 Posts)
  • STEVEN MARKS STEVEN MARKS @ 7:41 PM
    Contact this user
    Draft Hood
    I am replacing my existing oil burner with a Carlin gas burner. Is it necessary to replace the existing draft regulator with a draft hood? I was told I need to install a draft hood with a spill switch but I do not have the height. If I install the draft hood the vent will be pitched the wrong way.
    Steven
  • Steamhead Steamhead @ 8:30 PM
    Contact this user
    Not a draft hood
    a double-swing barometric with blocked-flue switch.
    If you're thinking of doing the conversion yourself- don't. This is not a DIY project. Hire a knowledgeable, experienced pro who has the proper equipment to set up a burner.
  • Jim Davis Jim Davis @ 10:16 AM
    Contact this user
    Advice
    Steamhead is absolutely correct.  Whoever recommended a drafthood should be avoided for any further advise!!!
