The Wall
Forum / Radiant Heating / Can a Circulator Pump Past a Stopped Downstream Pump?
  • Post a Reply to this Thread
    Can a Circulator Pump Past a Stopped Downstream Pump? (8 Posts)
  • VelvetFoot VelvetFoot @ 3:41 PM
    Contact this user
    I'm thinking about a piping schematic. I was wondering if a boiler circulator pump can pump past a downstream zone circulator that is stopped. I'm hoping it can't. Thanks.
  • Charlie from wmass Charlie from wmass @ 7:04 PM
    Contact this user
    why would it not be able to?
    yes it can. unless the head for that zone exceeds the pump curve.
    cell # 413-841-6726
  • VelvetFoot VelvetFoot @ 9:00 PM
    Contact this user
    I thought maybe the motor
    might be involved. Thanks for clearing it up for me.
  • Ironman Ironman @ 9:50 PM
    Contact this user
    Motor
    The impeller in the down stream circ will cause some resistance to flow, but like Charlie said, it won't stop it.
    Bob Boan
  • hot rod hot rod @ 6:03 PM
    Contact this user
    that's common in solar drainbacks
    two circs run to fill and establish the siphon, then the downstream one drops off, and goes along for the ride. A small pressure drop thru the un-powered one is all..
    I've heard of problems with trying to start the downstream one when it is spinning? Maybe they spin backwards sometimes.
    Also if you flow thru an unpowered ECM, like an Alpha the display lights up! Wonder if it turns into a generator?
  • Gordy Gordy @ 6:18 PM
    Contact this user
    Water turbine gen.
    To cancel out power used in the hydronic system. Even if it reclaimed something. System is circulating anyway.
  • Paul48 Paul48 @ 9:02 PM
    Contact this user
    Hmmm
    There might be a government grant for that one. If you could fold enough facts in to the nonsense, they'd probably go for it.
  • NYplumber NYplumber @ 8:42 AM
    Contact this user
    ashp
    I wouldn't be surprised if there is a grant for ecm circulator generators before ashps....
    :NYplumber:
