The Wall
Forum / Oil Heating / beckett aqua smart
  • Post a Reply to this Thread
    beckett aqua smart (2 Posts)
  • zepfan zepfan @ 8:07 PM
    Contact this user
    beckett aqua smart
    I had a few  questions regarding the beckett aqua smart control. first how long do they normally take to install on an existing oil fired boiler of appx. 20 years of age? do they  really provide a savings in fuel usage? I know that this control is now used by beckett to replace the heat manager that they, beckett, have stop making. we have a customer that has high fuel usage and I was looking at installing one of these on their boiler. thanks to all
  • earl burnermann earl burnermann @ 11:53 AM
    Contact this user
    Questions
    How well insulated and air sealed is the home? Is the boiler running close to it's rated efficiency? Could there be a leak in the oil return line if it's two pipped? If the current boiler is using a triple aquastat then the change should be pretty simple. But if the home's oil consumption is unusually high then I would look to see what is causing it.
    If the women don't find you handsome, they should at least find you handy!
