The Wall
Forum / THE MAIN WALL / MunchkinT80 Error codes
  • Post a Reply to this Thread
    MunchkinT80 Error codes (5 Posts)
  • Drippy Drippy @ 7:08 PM
    Contact this user
    My boiler is not making DHW and I have an error code of F-13. Any guesses?
  • BobC BobC @ 9:01 PM
    Contact this user
    Fan speed?
    I don't know anything about them but I did find this -
    http://www.heatinghelp.com/forum-thread/141189/Munchkin-926-upgrade-gives-F13-error
    Bob
    Smith G8-3 with EZ Gas @ 84,200 BTU, Single pipe steam
    3PSI gauge
  • Slimpickins Slimpickins @ 4:00 AM
    Contact this user
    Swirl plate
    Sounds like a bad swirl plate on the inducer. Its been a few years since I've seen that problem and tech support can walk you through it but they probably won't because you're not a contractor. Liability ya know.
    This post was edited by an admin on May 24, 2014 4:06 AM.
  • Rich Rich @ 9:04 AM
    Contact this user
    Many times
    after replacing the fan motor assembly and cleaning swirl plate and the like the control module needs replacing also . You just gotta fix one problem at a time . Star with the swirl plate , try to fire , replace fan motor assembly , try it , control module is next .  Try to find a service guy in your area .  Has this boiler been maintained and / or serviced regularly ? Should have been .
    You didn't get what you didn't pay for and it will never be what you thought it would
  • icesailor icesailor @ 10:11 AM
    Contact this user
    DIY Errors:
    Futzing around with these boilers really isn't a DIY job and not even for someone that thinks they know what they are doing.
    Its not difficult, but if you run into difficulties, you are really going down the tubes. Unless you are an experienced professional, hire one. You won't be sorry.
