The Wall
Forum / Domestic Hot Water / Munchkin 199MLP R1 not heating
  • Post a Reply to this Thread
    Munchkin 199MLP R1 not heating (11 Posts)
  • PartieHonteuse PartieHonteuse @ 4:02 PM
    Contact this user
    [Solved] Munchkin 199MLP R1 not heating
    Hello Everyone,
    While doing research I came across this site and unfortunately due to my research turning up really no results I decided to go ahead and post.
    I have a Munchkin unit (see post title) that is suddenly not heating the water (gauge shows ~75) and sounds like it's running or doing something which I never noticed before.
    Either way - looking at the controller I don't see an error code but what looks to be a display of "nc" (see attachment).  Sadly I'm not sure which product literature I'm to be looking at as this is all new to me and the product has been retired.  From what I can tell it either means D5 is not connected or the boiler isn't connected to the bus.  Either way, I can assure you that nothing has changed electrically in the house since last night.
    I'm pretty handy when it comes to electronics etc (IT Director) but if you believe it's more than just replacing a simple part and requires complete tear down of the system could someone provide a good residential HVAC company in the Attleboro or Seekonk, MA area that would be able to service?
    Thank you,
    -Mike
    This post was edited by an admin on July 2, 2014 8:04 AM.
  • kcopp kcopp @ 11:16 PM
    Contact this user
    That is a internal processor...
    error. Either the voltage is wrong or the neutral going to the boiler is broken/ damaged.
  • PartieHonteuse PartieHonteuse @ 12:20 AM
    Contact this user
    Thank you...
    kcopp, for the response.
    I hate to sound dense but I have to ask to make sure I understand this...
    "This is a internal processor" - i'm assuming you mean the controller board processor?
    ..."going to the boiler is broken/ damaged."  - Is it possible to elaborate on this on a little more?
    I consider the "Boiler" to be the entire unit - including circuit boards and their connectors.  Should I assume that you mean that any of the 3 neutral connections (that i can see on the wiring diagram connecting to X4, X6, and X6 block on the controller board) are a possible error point?  Or do you specifically mean the neutral line coming from my main home electrical panel into the junction box attached to the outside of the boiler housing and going into the X6 block on the controller board?
    Thank you again,
    -Mike
  • Rich Rich @ 8:53 AM
    Contact this user
    Location
    Mike , where are you located ? Could you post the serial number of the boiler ?
    You didn't get what you didn't pay for and it will never be what you thought it would
  • PartieHonteuse PartieHonteuse @ 9:41 AM
    Contact this user
    Requested info
    Hi Rich,
    I'm in Attleboro, MA
    S/n: L07K1425
    Thank you,
    Mike
  • Rich Rich @ 10:26 AM
    Contact this user
    HTP
    East Freetown Mass .  Contact them to find a local authorized contractor .  The control module and display if needed are what I would consider inexpensive if in fact none of the earlier mentioned items are the culprit .
  • PartieHonteuse PartieHonteuse @ 11:00 AM
    Contact this user
    yeah...
    Already planned on giving them a call on Monday seeing as how they are closed on the weekends.  Was just hoping to find a solution before then.  Having a 7month old an no hot water is proving....interesting.
    -Mike
  • Rich Rich @ 11:06 AM
    Contact this user
    Blog
    portion of their site may get you a lead on local knowledgeable contractor , site has been evolving regularly but you should be able to locate the blog . Jason A is very responsive as long as I have been involved using their products (quite awhile) . Give that a try
  • PartieHonteuse PartieHonteuse @ 8:11 PM
    Contact this user
    Well that was fun..
    Update and more questions.
    I found a local technician that came out and found that the controller went bad.
    I have a curious question though - does anyone have an image of the back of the 925 (not 926) controller?  The solder side not component side.  I've tried Google searching but came up with either only the 926 or just the component side of the 925.
    Would be even better if someone knew of a replacement transformer part # from digikey or the link.
    Thanks again.
    -Mike
  • Rich Rich @ 11:19 PM
    Contact this user
    New board
    Those Munchkins with the 925s are serial number specific . Not sure but don't believe what you are thinking is worth the effort . You can probably have a board and be enjoying hot water before all the research
  • PartieHonteuse PartieHonteuse @ 6:43 AM
    Contact this user
    Not what you're thinking
    Oh don't worry I already have hot water and a new controller. I was inferring that on my previous post. Got a 926 now.
    The questions above are for my own knowledge. I get that the boards are programmed but I doubt the transformer issue (assumption) caused the board to erase the programming from the IC.
