The Wall
Forum / THE MAIN WALL / Direct Venting Slant/Fin Intrepid TR-30 HPT
  • Post a Reply to this Thread
    Direct Venting Slant/Fin Intrepid TR-30 HPT (2 Posts)
  • Pologuy9906 Pologuy9906 @ 9:44 PM
    Contact this user
    Im having a wood gassifiier installed and won't be able to use the chimney. I know when I purchased this unit it was an atmospheric unit as well. I know many don't like DV but the oil will rarely come on. Will this unit require anything special besides a DV kit?
    I also wanted to know the best way to isolate each of my 5 zones in order to change my current baseboard to low temp baseboard without interrupting the rest of the system.
  • kcopp kcopp @ 6:35 PM
    Contact this user
    Direct venting....
    an Oil boiler is not something you add to a set up...it is a package you buy. Since you had an natural draft set up that is all you can do. It has to come from the factory set up and certified to do that.
    Now you may be able to by a power venter by Field or Tjernlund....
