The Wall
Forum / THE MAIN WALL / Antique something??
  • Post a Reply to this Thread
    Antique something?? (4 Posts)
  • ChrisJ ChrisJ @ 9:38 PM
    Contact this user
    Antique something??
    I found this in one of my crawl spaces mixed in with a pile of galvanized pipe and the big inserts that came from a converted coal boiler I assume. You know, the big iron ones that slide into the large passages.
    Anyway, it appears to say Rich Fin and 30 gallons. There is some number before that but I can't make it out.
    Does anyone know what this is?
    Weil-McLain EG-45 connected to 392sqft of radiation via two 2" risers into a 3" drop header and 2" equalizer. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
    Steam system pictures updated 6/5/14.
    https://picasaweb.google.com/thetube0a3/Boiler?authkey=Gv1sRgCImUxIqv9436MQ#
  • Larry Weingarten Larry Weingarten @ 2:46 AM
    Contact this user
    I'll guess...
    ... that it's a heat exchanger for hooking up to a 30 gallon tank for domestic hot water.  It would go in the fire box.  In cook stoves, they were called water fronts or water backs.  Maybe someone else will have a better informed guess!
    Yours,  Larry
  • icesailor icesailor @ 10:12 AM
    Contact this user
    HX:
    I think you have it. Especially if there is no plug in the second port. The ones I saw went on a Florence oil stove, like a side arm heater. Except they went into the side of a stove with the Kerosene pot burners. They were around when I started, but the Boss didn't service them unless we ripped them out.
  • ChrisJ ChrisJ @ 10:17 AM
    Contact this user
    Interesting
    Yep, no plugs in the first two ports, the second two have plugs. Looks like probably 3/4" NPT.
    I was surprised I couldn't find anything at all on this. Usually when I find an old name on an item like this I can find something, but not this time.
