The Wall
Forum / THE MAIN WALL / converting inches water column to psi
  • Post a Reply to this Thread
    converting inches water column to psi (11 Posts)
  • smoore smoore @ 10:30 PM
    Contact this user
    When dealing with gas preasures how do you convert inches water column to psi?
  • D lux D lux @ 10:37 PM
    Contact this user
  • Floyd Floyd @ 10:46 PM
    Contact this user
    2000 International fuel gas code book....
    > _A
    > HREF="http://www.heatinghelp.com/getListed.cfm?id=
    > 169&Step=30"_To Learn More About This Contractor,
    > Click Here to Visit Their Ad in "Find A
    > Contractor"_/A_
  • JimGPE JimGPE @ 1:24 PM
    Contact this user
    Don't listen to Larry - I think he's thinkin' ounces. (Sorry, Larry....)
  • Floyd Floyd @ 10:50 PM
    Contact this user
    page 106..... 27.7 in. H2O = 1 psi.
  • Larry Larry @ 11:07 PM
    Contact this user
    Roughly 28\"= 1 PSI
    Best I can come up with is a mult. to convert 1 foot of water to psi. Feet of water x 0.4335= PSI. I divided .4335 by 12 (in per ft) for a mult. of .036125. So, inches of water x 0.03625 = PSI. 1 (PSI)/0.036125=27.682...roughly 28". Larry
  • canuckDale canuckDale @ 11:17 PM
    Contact this user
    Hmmm....When in Rome
    I've always used 27.8. Have read 28.8. Guess it depends whether the code author resided in a costal place (sea level) or a mountainous place? Just like it affects those darn gas orifices. Oh I have a story to tell over a campfire and some libations about a boiler company in Ohio and a delivery in Alberta Canada. ;-) I live at 3500' above sea level.
  • corey corey @ 12:59 PM
    Contact this user
    Temp is a factor
    Temperature is a factor depending upon precision needed: 1 lbf/square inch (PSI) = 27.707591 inch H2O (60 F) 1 lbf/square inch (PSI) = 27.680671 inch H2O (39.2 F) Also, molarity: 1 foot H2O (39.2 F) = 0.974191 foot seawater See http://www.onlineconversion.com/pressure.htm
  • Joe at krahezfoo@aol.com Joe at krahezfoo@aol.com @ 8:11 PM
    Contact this user
    To coreysnow from joe
    Your equation of 0.974191 ft/seawater only holds true for measurements taken from the North Atlantic or Adriatic Sea. You would have to make a correction factor for readings taken from the Great Salt Lake, the Dead Sea, or the Caspian Sea. The converse holds true for the brackish waters that contain less salt than the aforementioned. Pi-delta-t has to be factored into it. Or square the difference between the densities. Hopes this helps!
  • Joe at krahezfoo@aol.com Joe at krahezfoo@aol.com @ 8:19 PM
    Contact this user
  • Dave Flood Dave Flood @ 11:22 PM
    Contact this user
    one pound of pressure will raise a column of water 27.7 inches high. We measure most residential and light commercial gas sysems in water column. Most LP systems operate at 11" wc. Most natural gas sysems work at 3.5 " wc. Dave Flood Director of Tech Ed ICPA Wallingford, Ct
