The Wall
Forum / THE MAIN WALL / munchkin gas leak
  • Post a Reply to this Thread
    munchkin gas leak (6 Posts)
  • peter dawson peter dawson @ 6:21 PM
    Contact this user
    Munchkin 80m gas leak
    We have installed a new controller 925, along with this we replaced he blower motor. There is a cork gasket between the blower and the gas valve. The new controller uses variable speed for the blower. We suspect at low speeds because of the lack of vacum the gas is leaking around the joint. The original blower always ran at full speed (old controller didn't support variable speed)
  • good guy good guy @ 7:55 PM
    Contact this user
    Try checking the gasket right under your nose!
  • munchkin-man munchkin-man @ 8:21 PM
    Contact this user
    Did it ever cross your mind to call tech support?????????
    800-323-9651 ext. 925
  • This post has been deleted!
  • RichW RichW @ 7:54 PM
    Contact this user
    gas leak
    I just came from one we installed awhile ago. Cust. claims he could smell gas intermittently. Two guys were there before me. I checked everything twice. Then I noticed that the pressure switch hose was off...no more gas leak...
  • munchkin-man munchkin-man @ 7:36 PM
    Contact this user
    Sorry no Sunday night tech support
    Unless one of us happens to be on the wall on sunday. Dose any other water heating equipment co offer these hours? 8am to 8pm mon thru fri and sats 8am to 11am.
  • good guy good guy @ 7:51 PM
    Contact this user
    Is there a tech support # that you can call on Sunday late that I don't know about?
