The Wall
Forum / THE MAIN WALL / Lennox Model Numbers...............................(Starch)
  • Post a Reply to this Thread
    Lennox Model Numbers...............................(Starch) (5 Posts)
  • John Starcher John Starcher @ 6:15 PM
    Contact this user
    Someone posted here.......
    ....quite a long time ago with a "decoding" chart for lennox model numbers, and how they relate to equipment size. Specifically, I'm looking at a HS29-261-3P condensing unit. What is the BTU rating of this unit??? Thanks, Starch
  • Jeff Lawrence Jeff Lawrence @ 8:33 PM
    Contact this user
    hope this what you're looking for
    Lennox equipment: 211= 1.5 ton, single phase 261= 2 ton, single phase 311= 2.5 ton, single phase 411= 3 ton single phase 413= 3 ton, 3 phase 461= 3.5 ton single phase 463= 3.5 ton, 3 phase 511= 4 ton single phase 513= 4 ton 3 phase 653= 5 ton 3 phase The Wall strikes again! To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"
  • Jared M Jared M @ 8:38 PM
    Contact this user
    Lennox model numbers
    14= 1 ton 21= 1-1/2 ton 26= 2 ton 31= 2-1/2 ton 41= 3 ton 46= 3-1/2 ton 51= 4 ton 65= 5 ton So, your unit is a two ton model. The HS stands for high side, HP for heat pump. The next two numbers are the series of unit, they generally work up as they introduce new models. Then a dash and the next two digits which are the capacity, see above. The third number between the dashes indicates single phase or 3 phase, a single phase unit in your case. And the last numbers after the next dash will be the series number and sometimes a letter which indicates the voltage So an HS29-261-1P is an air conditioner, 29 series, 2 ton, single phase, first revision (we call that the dash number, important when ordering parts) and the P stands for 208-230 volts. -Jared
  • John Starcher John Starcher @ 10:24 PM
    Contact this user
    That's why......
    ....I love this site! Thanks, guys. I knew I'd find an answer here. Starch
  • gmr1234 gmr1234 @ 3:43 AM
    Contact this user
    Lennox heat pump
    Hi. Anyone know if you can buy a new one of this model (HP19-261-3P) or at least a replacement?
    Thanks. Garry
