Forum /
THE MAIN WALL /
Is there an RF outdoor reset?
Post a Reply to this Thread
Is there an RF outdoor reset? (5 Posts)
It seems like I saw an advertisement for an outdoor reset sensor
that used radio signals to communicate with the indoor control panel. We have an installation where it would be nearly impossible to run a wire continuously from the boiler room to any outside wall. Any suggestions? Thanks, Luke Lefever -
Here's one, but it specifically states "commercial and industrial sized equipment" Fireye
Mike- where did you see that on Fireye's site? I don't find anything. Called them, they say they don't have anything, but that I should call Heat Timer in New Jersey. They have it (for $17,000) as part of an integrated boiler control system. Any other suggestions out there? Thanks, Luke
Looks like I took \"remote\" too literally...
"The E340 Boiler Control is a micro-processor based Boiler Management System designed to interface with existing Fireye Flame-Monitor and D-Series Flame Safeguard control systems, as well as competitive flame safeguard control systems. It consists of a chassis, plug-in programmer module, plug-in keypad/display module, for system configuration and display of system setpoints and operating parameters), wiring base, solid state sensors steam, gas, and oil pressure; fuel oil, stack, outdoor air, and water temp.), and remote communication software." Other than this, my web search struck out. Hard to imagine a basement where you can't get out somewhere and distances are quite liberal as long as you're not using the mechanical type with capillary tube and sensing bulb. -
The installation is a church, with newly finished basement surrounding the boiler room. Both Burnham boilers are leaking, if we can't get them to stop leaking with dope, then they are looking at replacement. I would encourage them to go with condensing, in which case we can go up the chimney with the 18-2 necessary for the outdoor sensor. I guess someone will eventually make one- but not yet. Thanks for the advice, Luke
