The Wall
Forum / THE MAIN WALL / Ultra Controls
  • Post a Reply to this Thread
    Ultra Controls (5 Posts)
  • Bob Sweet Bob Sweet @ 10:33 AM
    Contact this user
    The Ultra comes with ODR
    ready to go, with some minor parameter adjustments. I like to use a 3-way motorized mixing valve on the floor warming side of the system and base it off of ODR to modulate your floor temps or just base it off of a set point temp. Or you could use an injection pump to feed your floor warming temp. You will have to do two temps for sure, even a basic three way thermostatic mixing valve would work, but is not a smart control and would be a last choice. To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"
  • Read his other posts Read his other posts @ 9:17 AM
    Contact this user
    Controls on Ultra
    This is probably a basic, dumb question - but now that we are going with a W-M ultra running 2 air handlers and 2 constant circ radiant manifolds(just for floor warming on the tile floors), what boiler controls are recomended? I beleive the ultra comes with a control package, do I need anything else for outdoor reset? I really want to go more baic than complex, all other stuff being equal. Thanks for all the help.
  • Floyd Floyd @ 5:51 PM
    Contact this user
    You have all you need...
    just install a Taco SR zone control to run the pumps for the air handlers, a simple outdoor t-stat like a Ranco etc11200 to turn the radiant pump(s) on/off.... you may not need to turn down the temps. for the tile floors, as I remember your air handlers were somewhat oversized, and you may be able to heat with some very low temps through them. I would pipe in such a way that you could add tempering later, if needed..... you will also find that the water temps. for the tile will be warmer than you think to actually get a warm "feel" from the tile. Floyd
  • Bob Sweet Bob Sweet @ 6:09 PM
    Contact this user
    Imo
    seeing as the AH are your main source of heat, getting any comfortable production of heat out of them with less than 120* is stretching it. To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"
  • Read his other posts Read his other posts @ 7:29 PM
    Contact this user
    Even with climate panel above subfloor
    with direct contact to 1/4 inch board and tile? I was thinking around 100. You guys are probably correct, and I like your ideas.
