Forum /
THE MAIN WALL /
RoosterBoy Install Pictures
Post a Reply to this Thread
RoosterBoy Install Pictures (12 Posts)
Your stove installation looks fine. Your attic insulation is installed wrong. The kraft paper should be installed next to the heated area. You have it reversed.
thanks guys yes the insulation was installed wrong and some day i will be up there to fix it i will also stagger the seams when i flip it around. thank you Jason
insulation
Is that pink-stuff insulation a second layer or is it the only layer? If it is the only layer then flip it over. If it is a second layer, then you *should* peel off the kraft paper or get unfaced batts as a second (or more) layer in an attic. -
put in a new heater in my house check out my install thank you Jason
catalytic are cool :)
wheres the outside air for the combustion? is it the floor grill on the left of where you are standing? i tend to recommend bringing the outside make up air under the free standing with an opening close to the front. there is an additional gizmo that you can lash into the stack....which looks like a coffe pot / flour sifter ...it reduces stack to very low temps and reduces particulates by collecting them out of the previous combustion process. you can remove it close a little slider door ,clean it with the sifter squeezer handle and put it back from whence it came... i wish i knew who made them they have been around for a while... -
I think I see it if front of the cradle. Or are my eyes pulling a trick on me?
I think that's the diaper pail.
Tower
What is the tower in the back yard used for :) -
N/A October 11, 2006 @ 11:50 AM
wondering what
Wondering what does the cannon do at the base of ur fireplace? Does it fire automatic when the fire get low? Otherwise, its a nice installation! -
well
the crowd on the TV seems to like it :) Nice job Scott To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional" -
wondering what
N/A October 11, 2006 @ 8:46 PM
the radio tower
I'm sure after reading "thanks, brad white" post, Jason want Scottie to beam him up.....
