The Wall
Forum / THE MAIN WALL / oil tank question
  • Post a Reply to this Thread
    oil tank question (2 Posts)
  • Darren Darren @ 8:34 PM
    Contact this user
    Questions reguarding oil tanks.
    If you feed a gravity style kerosene heater from the top of an oil tank and you have a dip tube to the bottom of the tank, Will the oil continue to flow if the unit doesn't run for several days. My thinking is that once the syphon has begun it will always be there unless you run out of oil. Am I correct? The old tank is a bottom feed and the heater works well but I would like to change it to double wall which would feed from the top. I just didn't want to start problems. Darren
  • brucewo1b brucewo1b @ 8:47 PM
    Contact this user
    In a perfect world yes
    but we all know its not a perfect world and air can make it in where oil will not leak out.
